Meet our team of experts
The Renaultsport Experts area gives you the expert advice from the Renaultsport experts themselves.
Allen Collen
  • Products
  • Technical
Read Allen Collen's Biography
Allen Collen has worked within the motor industry for the past 20 years. Starting at the ground and working up he has developed a wide appreciation for what is required and what can be achieved. Currently Allen works with RUK looking after the technical aspects of their Motorsport programs as well as providing technical support for special projects and other bespoke activities.
Your Question
Latest Questions
r-link RS button monitor
Hi, I've just bought a 2015 Renault Megane RS Nav 275 and was dissapointed to see it didnt come with the RS button monitor. Is there a way to activate the RS button or add it? Or does this feature only come with the Megane RS Cup -S?
Garry, 28th Nov 2017
Hello Garry, I'm informed it is a factory only option and cannot be changed in after sales. Kind regards,
allencollen.jpeg Allen Collen, 28th Nov 2017
orange warning light on dash
Hello I have a 2010 Megane FF Rs250. Orange warning light is showing "Check injection sytsem" on dash display. Diagnostics is DTC023 Turbocharger water pump command intermittent and permanent. Is there anything I can check myself.? Thank you.
Ian, 10th Nov 2017
Hello Ian, The most you can carry out would be to check the connections and fuses. Beyond this, diagnostic equipment is required. Kind regards,
allencollen.jpeg Allen Collen, 10th Nov 2017
Clio 220 trophy tracking
Hi. I have recently taken my vehicle to a renaultsport certified dealership. Having told them my alignment was out I arrived hoping to have the tracking done. Turns out that the hunter machines used at the dealerships dont have the correct adapter for the new clio 220 trophy design alloy wheels, so in brief they couldnt help me, which I find quite poor. I cannot be the first person to have hit this issue but its clear the dealerships dont have the correct tools to perform alignment checks and adjustments on the latest gen clio with the standard wheels fitted. Thanks
Ben Barnard, 3rd Nov 2017
Hello Ben, I completely agree - have you contacted Renault Customer Services?
allencollen.jpeg Allen Collen, 3rd Nov 2017
CO2 Emissions - Clio RS Lux Cup pack
Hi, Having recently bought my car in the UK, I am in the middle of trying to have it registered here in Ireland. Part of the process means paying an additional vehicle registration tax which hangs largely on its value and carbon output. They've put the car in the higher band of 144 g/kg where most specs on Renault dealer websites, and other sites quote 133 g/kg. The financial difference is substantial. Are you able to confirm the actual carbon emissions value? I'd be greatful if you could as it might help put it to bed. Thanks, Lewis
Lewis, 25th Oct 2017
Hi Lewis, You really need to contact Renault Customer Services to obtain anything official. Kind regards,
allencollen.jpeg Allen Collen, 25th Oct 2017
2011 Megane RS 265 Trophy
Recently the last few days I have noticed when under hard acceleration (High RPM) and upshifting from fourth to fifth I have noticed a slight hesitation to engage gear correctly, a feeling of something blocking the gate. If I depress the clutch then disengage the gear then depress the clutch again it engages correctly. This problem only occurs when changing to fifth and does not affect any other gear at all. Also this problem only occurs at high RPM and at slower speeds, fifth gear works perfectly" "The rest of the gears work perfectly at all speeds". "In your experience is this a common fault? If so what do you think is causing it?"
Daniel, 23rd Oct 2017
Hello Dan, It's possible the syncro mechanism is worn. Its quite rare and would generally affect the lower gears before the higher one's but a lot is dependant on duty cycle. Apologies for the delay in responding and i hope you get it resolved.
allencollen.jpeg Allen Collen, 23rd Oct 2017
133 Silverstone
Hi, Just picked up a Twingo 133 Silverstone and found someone has lowered it further by cutting the springs. I cant seem to find a supplier of the original springs can you point me in the right direction? Part number maybe?
mark, 17th Jan 2018
133 Silverstone
Hi - a Renault dealer can order the parts for you. They will just need a registration number for your car
jeremytownsend.jpg Jeremy Townsend, 17th Jan 2018
Winter tyres Renaultsport Twingo 133 Cup
Ask similar to your colleague Mr Collen couple of weeks ago but no response - and when I tried to 'phone last week the 'phones were of frustration here ! Need to fit 195/40 R 17 Winter tyres - there do not appear to be any in Europe - BUT I can get from Germany 165/65 R15 on a steel 5 inch x 15 ET 38 bolt circle 4/100 in a Winter pattern .Will they fit ? The spare with the car is 185/55 R15 .My first 'Renault Sport was a Dauphine Gordini Autocross car in the 60's so I have been[gulp!] around a bit ! Thank you Simon Bird 01686 420284
simon bird, 16th Jan 2018
The winter tyre set up that we recommend is a 195/45R16 84H tyre on a 7J x 16 rim. ET 55 bolt circle 4/100
jeremytownsend.jpg Jeremy Townsend, 16th Jan 2018
Clio rs 220 trophy (1)
Hi do Renault do any performance upgrades for the 220 ?
Paul, 10th Jan 2018
Hi - sorry, we don't approve any performance changes
jeremytownsend.jpg Jeremy Townsend, 10th Jan 2018
