Offline voyagerxp
#1 Posted : 18 November 2017 18:26:26(UTC)
voyagerxp
Hey guys ive just had a renault megane dynamique s nav dci and want to put a Nextbase 512GW dash cam in using the Next base hard wire kit. Ive got all the cables hidden and got it earthed but not sure what fuse i should attach too.
https://www.dropbox.com/...hnh124c5cjh46/3.jpg?dl=0
https://www.dropbox.com/...b1u4e1bewwwnl/2.jpg?dl=0
Offline dilfred
#2 Posted : 13 January 2018 19:51:03(UTC)
dilfred
DId you sort it?
I'd go for the USB one, it's easy access. This is not a permenant live, but only when ignition goes on.
Out of interest, how / where did you earth to? I have a temporary earth in my setup, but prefer a better solution.
Offline Bilbo
#3 Posted : 14 January 2018 08:40:16(UTC)
Bilbo
In my 175 dci I took th evolve box out and found an earth point up behind the dash I then tapped into the stereo ignition live as it only draws very little power 👍
Offline Bilbo
#4 Posted : 14 January 2018 23:31:50(UTC)
Bilbo
That’s glove box not evolve box 😂😂
