Offline x6411
#1 Posted : 07 June 2018 17:20:40(UTC)
x6411
Hi all
Front pads on trophy need replacing does anyone have any recommendations on which pads to put on? Stick with OEM?
Online del115
#2 Posted : 08 June 2018 08:34:07(UTC)
Originally Posted by: x6411 Go to Quoted Post
Hi all
OEM are fine for every day use.
Couple of guys I know are using EBC Yellow Stuff for track day exploits - apparently a bit more progessive and last well.
Depends on use I guess but as always its the bedding in process that is important.
#3 Posted : 08 June 2018 13:57:50(UTC)
I’ve had no problem with yellows on track
Just bought Ferodo ds1.11 from kam racing
Fitted pads with new discs front and rear on Monday but not had the car out yet so cannot comment yet
I will post when tried out in anger
#4 Posted : 08 June 2018 19:29:05(UTC)
I expect the ds1.11 will be far better than ebc yellow
Offline RSaddict
#5 Posted : 08 June 2018 21:32:47(UTC)
RSaddict
Anything other than OEM will be an improvement...
#6 Posted : 09 June 2018 07:39:14(UTC)
It’s weird that the standard renault pad material transferred over onto the discs thus causing lumpy pad deposits to sit on the disc causing judder
Are the standard pads a cheap sub standard pad that melts and sticks to the discs
No One that I know off has explained this and renault has totally denied that it’s their pad that’s the problem
I have tried many different pads and none of them give this pad transfer judder
Pagid euro car parts standard are ok but only seem to last one track day
Yellow stuff a little wooden but take the heat and last a few track days
Brembo from ecp again ok for track but don’t last long
Tried ebc green are ok . but gone down to metal after only half a track day 30 Laps or so
Ferodo DS1.11 still to try and will post up results
#7 Posted : 09 June 2018 09:13:00(UTC)
Watch out for the dust that comes off the ds1.11....
Offline beh
#8 Posted : 09 June 2018 15:25:49(UTC)
beh
Not sure what OEM was before, but on 2018 220T I got some kind of ferodo pads from factory (will try to read numbers tomorrow if possible, 2500 most likely). 1 track day so far and all is fine.
Edited by user 09 June 2018 15:51:00(UTC)  | Reason: Not specified
Offline x6411
#9 Posted : 11 June 2018 18:52:08(UTC)
x6411
Cheers for replies all.
Car won’t be going on track but the OEM pads haven’t lasted long at all. 7 month! 👀
Offline beh
#10 Posted : 18 June 2018 16:27:44(UTC)
beh
@shocker what disk were you using? OEMs with different pads or others?
#11 Posted : 20 June 2018 08:58:44(UTC)
Ebc Black slotted
But have now gone back to standard Brembo with the ds 1.11
