Meet our team of experts
The Renaultsport Experts area gives you the expert advice from the Renaultsport experts themselves.
Allen Collen
  • Products
  • Technical
Read Allen Collen's Biography
Allen Collen has worked within the motor industry for the past 20 years. Starting at the ground and working up he has developed a wide appreciation for what is required and what can be achieved. Currently Allen works with RUK looking after the technical aspects of their Motorsport programs as well as providing technical support for special projects and other bespoke activities.
X
Your Question
Latest Questions
Wheel and offset
Hi Alan, I have a stripped out track Megane RS mk3 running an array of track mods. I have just ordered a new set of wheels & tyres from Demon Tweaks and although they have told me that the car will have no issues with the new size wheels I am unsure! I currently run the standard 18” x 8.25” ET65 RS wheels with 235 x 40 x18 track tyres, the car is fitted with KW Clubsports and is lowered within the parameters stated by KW, the car is also running approx -3 dog camber at the front and -2deg to the rear. The new wheels are Team Dynamics Pro race 1.3 18” x 8.5” ET 45, I have worked it out if I’m correct that the new wheels will sit approx 23.5mm further out towards the arch than the standard wheel. I appreciate that this will to a certain extent put more pressure on bearings etc and it will probably make the steering slightly heavier but I’m hoping that that is the only issues and that the car should Corner better and should stay flatter through the bends owing to the extra width? Please could you comment and give me your advice. Many thanks, Regards, Nick
Nick Waddington, 14th Nov 2018
Wheel and offset
Hello Nick, Some reasonable changes there. It's hard to predict whether the new wheels will cause the tyres to foul the bodywork. If they do i suspect you might have to roll the inside edge of your bodywork to create greater clearance. Best wishes,
allencollen.jpeg Allen Collen, 14th Nov 2018
Alloy Wheel Paint Colour Code
Can you tell me what the paint colour code for the phase 2 gloss black Clio 220 Trophy alloys is please. Thanks
Christopher Stanley, 13th Nov 2018
Hello, The paint code is 205152 Kind regards,
allencollen.jpeg Allen Collen, 13th Nov 2018
Clio 1200, 2004
When should the cam belt be changed
Tony, 13th Oct 2018
Clio 1200, 2004
Hello Tony, Generally for 1.4 petrol engines - 72K miles or 5 years. However please check your cars service book for the most precise information. Regards,
allencollen.jpeg Allen Collen, 13th Oct 2018
Fuel filter
Hi I am struggling to find the location of fuel filter on my 225 Renault sport LM08EJL
Paul Williams, 9th Nov 2018
Fuel filter
Hello Paul, Unfortunately i've not seen the underside of this car. Please reach out to a Renault retailer who can be more helpful. Regards,
allencollen.jpeg Allen Collen, 9th Nov 2018
1999 Renault Megane 2.0 RXE
I have an old Megane with the F3R motor, I would like to know more about the valvetrain and ticking noises coming from the motor, it has noticeably less power below 4000 RPM and has a ticking noise at all temps that match engine rpm in timing as well. The tapping isnt as loud when you're not accelerating though.
Dino Gaggia, 2nd Nov 2018
Hello Dino, If you are getting noise from the valve gear it could be clearances due to worn buckets/followers. Regards,
allencollen.jpeg Allen Collen, 2nd Nov 2018
Megane RS 250 Cup differential fault
2010 model Megane 250 Cup, has done 56,000 miles. I heard a slight whining noise changing consistently with road speed, not engine speed. Main dealer mechanic had car on the ramp, and we heard a "clicking" from the front wheels when turned by hand. I am told this is a sign of a failed or failing differential, requiring a new gearbox. Car has not been abused! Is this likely to be correct and a not unknown fault, or am I just unlucky?
James, 6th Oct 2018
Hello James, I'd suggest you are unlucky and should reach out to Renault Customer Services for their support. Regards,
allencollen.jpeg Allen Collen, 6th Oct 2018
Key card battery (1)
I have a Renault Capture & the key card battery warning light is on how do I change or charge the battery
Bernie, 25th Sep 2018
Hello Bernie, i'd suggest getting a Renault retailer to change the battery - however if you would like to proceed with this yourself you will find the instructions inside the user manual. Regards,
allencollen.jpeg Allen Collen, 25th Sep 2018
Middle row seatbelts
My grand scenic says I have 2 seatbelts fastened in the middle row. I can see the cable that works it. Is there a common issue and is there a place to get a replacement cable?
Jeffrey Trayfoot, 25th Sep 2018
Hello Jeffrey, I'd suggest getting a retailer to investigate this - as a minimum they can define what parts are required. Regards,
