Meet our team of experts
The Renaultsport Experts area gives you the expert advice from the Renaultsport experts themselves.
Allen Collen
  • Products
  • Technical
Read Allen Collen's Biography
Allen Collen has worked within the motor industry for the past 20 years. Starting at the ground and working up he has developed a wide appreciation for what is required and what can be achieved. Currently Allen works with RUK looking after the technical aspects of their Motorsport programs as well as providing technical support for special projects and other bespoke activities.
X
Your Question
Latest Questions
Twingo R2 Brembo Callipers
Where can I purchase a pair for Brembo Callipers for the R2 Twingo Tarmac Spec. Thanks Matt
Matthew Humphris, 7th Dec 2018
Hi, please try R Sport. Kind regards,
allencollen.jpeg Allen Collen, 7th Dec 2018
CLIO 220 TROPHY SERVICE INTERVALS
Can you confirm the servicing requirements for the 220 Trophy? My car GF67THV was delivered on 3/12/17 and my dealer has just contacted me to have a 12mth service completed. The car has covered 8,800 miles since delivery. Information drawn from brochures/the RS website suggests the service interval is capped at 2yrs or 12,000 miles, whichever comes first, with the onboard service indicator dictating the ACTUAL requirements. The OBSI indicates the car needs servicing in either 3,200miles or 12mths, which ties in with the 12,000 miles/2yr info. Is the dealer correct or do I follow the cars actual indicated requirement? Many thanks, JWW
John Warren, 7th Dec 2018
Hi John, You are correct - please follow the on-board indicator.
Clio 182 info
I am looking to gather info on my car, how it came from the factory and whether it has both cup packs etc. It is a Clio 182 The reg is GY04PWN and vin is VF1CB220F31374728 Cheers
David Pollard, 6th Dec 2018
Clio 182 info
Hi, you need to ask Renault Customer Services. They have access to the vehicle registration database. Apologies for the delay.
allencollen.jpeg Allen Collen, 6th Dec 2018
R Link serial number
Hi my sat nav and radio have stopped working and I can’t find my serial number
Alan, 29th Nov 2018
Hello Alan, There is a ICE support page: https://easyconnect.renault.co.uk/
allencollen.jpeg Allen Collen, 29th Nov 2018
engine and gear mount
hi, i owe megane rs 265 2014, my engine and gear mounts need to be replaced. i was looking for oem numbers but i got confused. i found too many different numbers. can i have the right oem numbers for all gear and engine mounts? how many of these are exist?
tsiyon, 29th Nov 2018
Hello, You will need to obtain these from a Renault retailer. Best wishes,
laguna 3 2.0 diesel 180bhp
hi, whaqt is the correct idle speed for this engine? mine is idling at around 800rpm, however its vibrating quite a bit. when i increase revs slightly to maybe 900 its fine!?
ben fuge, 29th Nov 2018
Hello Ben, The engine idle speed will be dictated by a number of factors and should not be independently adjusted. If in doubt have a specialist review the operation. Kind regards,
TPMS Megane 3
I bought my 2015 Cup-S 2 weeks ago. The first few days were fine, then the weather temperature dropped. Now I’ve discovered that my wheels were swapped front to back and I’m getting tpms warnings ‘Adjust tyre pressure’ - no amount of ensuring the correct tyre pressures are present and ‘Learning TP initiated’ will clear the warming. Does it have to go to a Renault dealer to reinitialise the system or can I do it myself?
Peter, 26th Nov 2018
TPMS Megane 3
Hello Peter, You should be able to perform a reset, holding the button for a while.. like a very long press. If it doesn’t work then a dealer visit is recommended. Kind regards,
allencollen.jpeg Allen Collen, 26th Nov 2018
Megane 225 f1
Hi all, I’ve recently brought a Megane 225 f1, I’m getting a burning rubber smell on a hill start and when I put my foot down, I think it’s the clutch but it is not slipping!? Any advice would be great, cheers, jay
Jamie Benton, 26th Nov 2018
Megane 225 f1
Hello Jay, Its quite difficult to offer a strong opinion on this question but it could be influenced by your hill start technique. The engine is powerful enough not to require a lot of RPM at low speed. Kind regards,
