Offline David RUK
#1 Posted : 18 February 2009 14:03:39(UTC)
David RUK
Images should now resize correctly when uploaded to the forum.
If you're still experiencing difficulties, please post details here.
Thanks.
Offline dayc
#2 Posted : 22 February 2009 18:59:02(UTC)
dayc
Offline David RUK
#3 Posted : 23 February 2009 14:56:42(UTC)
David RUK
Looked into that dayc - it seems the resize function was only invoked if you use the "insert image" button and that those images were added using the img tags. Its now been rewritten so that the resizer works regardless of how the image is inserted - so hopefully should be ok now.
Offline Kirsty172
#4 Posted : 02 March 2009 22:34:15(UTC)
Kirsty172
yay!!!!!! fantastic!!!! ; )
Offline dayc
#5 Posted : 08 March 2009 14:07:39(UTC)
dayc
Posted this thread up last night in which the images did not resize....one for the techies me thinks??
http://www.renaultsport.co.uk/community/forum/Forum_postsm834501/Mid-Wales-Run--Pics/Default.aspx#834501
Offline mattk
#6 Posted : 09 February 2011 20:42:40(UTC)
mattk
Hi - not sure what I'm doing wrong with regard to image resizing - please see this thread:
http://www.renaultsport.co.uk/community/forum/Forum_postsm1014667/FIRST-PROPER-CUP-RUN--FROG-4/Default.aspx#1014667
I rarely have success uploading pics!
Matt
Offline Al
#7 Posted : 09 February 2011 22:30:29(UTC)
Al
Matt
Odd as the source http displays a correctly proportioned image, as does if I post it. Confused
Browser issue?
Edited by user 09 February 2011 22:32:47(UTC)  | Reason: Not specified
Offline mattk
#8 Posted : 09 February 2011 22:57:05(UTC)
mattk
That really is odd. I just tried again in Internet Explorer (usually always use Firefox) and it is still stretched. Can't see why you'd be able to link to the same picture as me and have it displayed correctly!
Offline mattk
#9 Posted : 09 February 2011 22:57:39(UTC)
mattk
Offline mattk
#10 Posted : 09 February 2011 22:59:09(UTC)
mattk
Out of interest, what is the ?id=651 bit on the picture you pasted that's not on mine, and where does this come from? Seems to be the issue...
http://farm5.static.flickr.com/4104/5431902858_e2bdd1be78_b.jpg?id=651
Offline Al
#11 Posted : 10 February 2011 17:58:43(UTC)
Al
The id is only referencing the location of the photo I believe;  I got the img tag http from right clicking and "copy image location". I added nothing that the original photos source provided. All a bit odd really as you've tried difference browsers - maybe there's an update for them with a patch?
Offline DrDrew
#12 Posted : 10 February 2011 19:07:46(UTC)
DrDrew
This would have to be quite strange to be a browser issue - @mattk have you tried Quoting Al's post with the image in and posting that? If that displays correctly then it could be that you're adding images differently somehow.
Offline Al
#13 Posted : 10 February 2011 19:51:05(UTC)
Al
I was only going on that there was (and still is I believe) an issue with different browsers causing some links to other sites to be selectable and others that just become plain text, even though both are c and p-ed.
#14 Posted : 10 February 2011 20:00:33(UTC)
The incorrectly sized pics are been specified as that size in the html.
Edited by user 10 February 2011 20:04:57(UTC)  | Reason: Not specified
#15 Posted : 10 February 2011 20:13:24(UTC)
If you use the image insert it should allow you to resize to anything you want
Offline mattk
#16 Posted : 10 February 2011 21:45:23(UTC)
mattk
Matt
Quote test!
Browser issue?
Offline mattk
#17 Posted : 10 February 2011 21:47:07(UTC)
mattk
Quoting Al's post worked - I add images using the image button and then just paste in the image URL. Will try another now, bet it will stretch!
Offline mattk
#18 Posted : 10 February 2011 21:48:55(UTC)
mattk
Offline mattk
#19 Posted : 10 February 2011 21:49:44(UTC)
mattk
Just done the above using the right-click and 'Copy Image Location' method, and still stretches!!! Think I will just post links to my albums in future, much easier! grr!
Offline DrDrew
#20 Posted : 10 February 2011 23:01:19(UTC)
DrDrew
I've been having a bit of a play with this, and it appears that the behavior of the "insert image" field varies quite wildly across platforms, with regards to the content that actually appears in the rich text editor - (wont bore you with the more techie functional stuff).
@mattk the easiest way around this for you that I've found would be to just type in the custom image tag braces. In the case of this forums' setup it you can simply type img in square brackets - [ ] - infront of your link and /img in square brackets behind your link. i.e. [*img*]http://www.someimageurl.com/img.jpg[*/img*] but without the asterisks. (had to put them in so this post doesn't go off looking for an image.)
This also seems to be very pliable as to adding in your own image attributes, so if you want to set a specific width and height you can write [*img width='510px' height='100px'*]...url...[*/img*]
Offline mattk
#21 Posted : 10 February 2011 23:36:03(UTC)
mattk
Offline mattk
#22 Posted : 10 February 2011 23:38:17(UTC)
mattk
Thanks DrDrew - the [*img] method does indeed work and I shall use that from now on! Really odd behaviour from the image button.  Just glad it works, shall now post some piccies!
MattBig Smile
#23 Posted : 20 February 2011 15:28:01(UTC)
Using the uploader this comes out wonky
Tried the IMG thing but it comes out mahoosiveConfused
#24 Posted : 20 February 2011 15:28:56(UTC)
Hmmm, it did beforeBlushConfused
Offline DrDrew
#25 Posted : 20 February 2011 18:49:01(UTC)
DrDrew
I believe if all works correctly it should initially appear large, and then be resized (by javascript) on page load. The on page resizing doesn't always show in preview modes, and depending on various factors javascript CAN mess up occasionally.
Image resizing. (Developments & Feedback)
by steviant 22/04/2008 12:35:57(UTC)
