Offline Tasha.j99
#1 Posted : 10 May 2017 15:28:03(UTC)
Tasha.j99
Hi
I've recently bought a 2008 (08 reg) gt and there seems to be an electrical fault to do with the clocks. I've been told to replace them but I was just wondering if I could order a standard twingo of the same age set of clocks and would they work alright in it? Just thinking of availability as I've not had much luck finding parts off of old twingo gt's.
#2 Posted : 10 May 2017 18:58:30(UTC)
When you say clocks, what exactly do you mean?
Offline Tasha.j99
#3 Posted : 11 May 2017 13:16:03(UTC)
Tasha.j99
Basically the dashboard, where it displays mph and any warning signs.
At the minute mines displaying all previous wanting signs due to the previous owner fitting the clocks wrong and tripping the electrics.
#4 Posted : 11 May 2017 19:10:38(UTC)
From memory, the centre display radio screen differs based on the stereo type chosen but the speedo part is the same regardless.
Are you sure you can't simply reset the warning lights via an OBD reader?
Offline Tasha.j99
#5 Posted : 12 May 2017 11:39:02(UTC)
Tasha.j99
Even if I reset the lights the clocks have been fitted wrong so it'll just keep getting tripped randomly, if we swapped the clocks over I can get it fitted properly and the wires will get sorted but I just wanted to know whether or not I could get a set from a standard twingo or it has to be a GT
