Offline DeanieBeanie85
#1 Posted : 25 January 2018 22:26:34(UTC)
DeanieBeanie85
Sorry guys/gals, couldnt see where i could post this so just taking a chance.
Im not clued up with all this but im seeing if anyone can help, i only have an 07 1.4 Clio, i think i let the fuel run too low last week and noticed in 2nd gear accelerating it statted the chug a bit, today it got alot worse in 3rd, i was hoping topping it with fuel and maybe some liquid i can buy from Halfords to hopefuly help clear any crap may do the job but a friends thinks it may be the fuel filter? Is this easy to change for somwone with no experience?
Thanks for your time
#2 Posted : 26 January 2018 07:11:50(UTC)
Fuel filter is normally incorporated into the fuel level/pump unit which is in the fuel tank & needs replacing at around 90000 miles.
Your description sounds more like ignition pencil ignition coils' & spark plugs which is a more common issue especially if not maintained correctly.
#3 Posted : 26 January 2018 07:23:06(UTC)
DeanieBeanie85
Right okay, are these usually expensive fixes?
#4 Posted : 26 January 2018 07:38:17(UTC)
Out of the two the spark plugs and coils is the easiest and cheapest.
If you are going to do the work yourself I would advise you to buy a Haynes manual and get to know what is involved.
#5 Posted : 26 January 2018 11:59:46(UTC)
DeanieBeanie85
Thanks alot, i have a mobile mechanic coming out he thinks itll be sparks, fingers crossed
