Offline nemo
#1 Posted : 25 July 2017 10:07:18(UTC)
nemo
http://i64.tinypic.com/mkbp4y.jpg
Good morning, I found this broken vacuum pump pipe (?). I can not find the replacement, what is the oem code ? How can I replace it?
Offline Therameatelf
#2 Posted : 23 March 2018 12:50:13(UTC)
Therameatelf
Hello, try it yourself. I advise you to buy a tube meter, a valve and several different collets for experiments. The vacuum valve is really perfect from the "classics"ю I used it for my car in golferexpert.com The only thing to connect it with the tube will have to take a piece of rubber hose with an internal diameter of 9-10 mm. On the valve, the hose is pulled with great force and it will not fall off exactly, but on the pipe side you need to put a yoke. Good luck!
Edited by user 27 March 2018 06:27:51(UTC)  | Reason: Not specified
Offline RobertLewis
#3 Posted : 19 June 2018 15:55:20(UTC)
RobertLewis
I do not know how about the pipe, but I can advise you to look good caps and different headgear)
