Offline Si
#1 Posted : 19 April 2019 16:01:27(UTC)
Si
Hi all
I have a 2015 megane 265 rs.i love the car and it makes me smile when I put my foot down.
Problem is stopping it seems to suffer badly from brake fade when they are hot . Despite the huge brembos on it
Which pads and discs should I be looking at
Si
#2 Posted : 19 April 2019 19:54:24(UTC)
Have you serviced the brakes recently?
Offline Si
#3 Posted : 19 April 2019 20:09:41(UTC)
Si
Only had car about a month so not d
Done them myself yet
#4 Posted : 19 April 2019 20:20:48(UTC)
Front calipers can suffer from sticking pads. Strip them down and give them a clean.
Offline Si
#5 Posted : 19 April 2019 20:31:41(UTC)
Si
Thanks John I will give it a go over the bank holiday.
#6 Posted : 23 April 2019 08:12:51(UTC)
I'd change the brake fluid too.
It goes off after a few years and is worth changing. It's a messy job but it's not hard to do yourself if you use an EZ Bleed.
If you're just using it on the road, any decent Dot 4 should do the trick, if you're planning on doing trackdays then it's worth getting something a little better (I used Motul RBF600 when I did mine).
