2 Pages<12
#26 Posted : 07 July 2019 16:33:33(UTC)
Honda acknowledge that their ring record specification can’t be purchased off the shelf
Offline Kirsty172
#27 Posted : 07 July 2019 17:04:31(UTC)
Kirsty172
What are the differences?
#28 Posted : 07 July 2019 17:21:02(UTC)
Car had a cage, no radio/nav and non-std tyres
#29 Posted : 07 July 2019 17:38:54(UTC)
Wasn’t it partially stripped too?
#30 Posted : 07 July 2019 17:52:12(UTC)
Yes, rear gone to make way for the cage. Apart from the trick tyres, it’s the same mods that Renault did for the 275 Trophy-R. The important difference was that Renault had the spec for sale, Honda didn’t
Offline MrRS
#31 Posted : 07 July 2019 20:17:33(UTC)
MrRS
Honda always said they compensated the extra weight from the cage by dropping a few bits off like the air con etc. Fair enough but they didn’t run it on factory spec tyres which was a cop out. Rumour has it they were the Michelin Cup 2. Regardless, it was a very impressive lap time on a car hugely cheaper than the Trophy R. Lots of talk the Ring spec Trophy R will be about £70K ish. Emmm.
Offline if1
#32 Posted : 07 July 2019 20:48:10(UTC)
if1
So did the 275 trophy-R employ a roll cage as well?
Online Breadvan Matt
#33 Posted : 07 July 2019 20:56:11(UTC)
Breadvan Matt
What Craig states is 100% true.
The Honda that went around the ring had no back seats, a roll cage and special sticky tires. Honda themselves admitted this. They defended the rear seat removal by stating that any weight saving gains were offset by the weight of the cage). This may or may not be true but either way, these are all things that are not available (either standard or as options) in your local Honda dealership. So technically it wasn't a standard production car.
Making these items an option on production car is very expensive hence why I'd imagine Honda never offered them.
#34 Posted : 07 July 2019 21:10:16(UTC)
Originally Posted by: Kirsty172 Go to Quoted Post
I find the lies ascertion very hard to believe.
The marketing of 4ws is just messy now. Anyone who truly values that will also know that the super duper megane doesn't have it. So who are you marketing this at?
Don't worry too much about marketing. If you can do better, give them a call on Monday, they'll snap up your services and will pay you handsomely. Perhaps.
#35 Posted : 08 July 2019 21:36:42(UTC)
No
#36 Posted : 08 July 2019 22:42:48(UTC)
I vaguely think from what I've seen/read the 275 Trophy-R is the quicker beast than the CTR on circuit when tested independently so could suggest the Honda ring times were questionable. Just looking at the tyres alone I'd put my money on the Trophy-R. That said clearly the CTR is right there at the top of the none stripped out hatches.
Offline MrRS
#37 Posted : 09 July 2019 05:33:27(UTC)
MrRS
The Renaultsport engineers were just given the old 4WS Megane GT to turn into the RS version, so unfortunately their hands were tied. The 4WS always gets mixed reviews.
I reckon given a choice they would have preferred not to have 4WS on the 280/300. As proven when they had a bigger budget and more scope to modify and then dropped it on the Trophy R.
#38 Posted : 09 July 2019 10:24:03(UTC)
Not proven at all. They needed to save weight and had 2deg of front neg camber to play with so it was the obvious solution for the R design brief. As I said, for turn in and track use, 4WS is brilliant if you want to keep a more versatile car. I wouldn't run 2deg on a trackable daily, would you?
Offline MrRS
#39 Posted : 09 July 2019 16:41:09(UTC)
MrRS
So what you are saying is for track use, the weight and complexity of 4WS offsets any real advantages. Particulary when front wheel camber is independent from rear wheel steering angle anyway.
#40 Posted : 09 July 2019 18:19:34(UTC)
What is the Trophy R time compared to the regular Trophy?
What are you driving just now?
#41 Posted : 10 July 2019 22:16:24(UTC)
I can't remember saying that, including talking about complexity. It's a choice, saving weight and compensating by adding 1 deg of neg camber on a track focused car vs running a more versatile car with road friendly camber and having the benefit of saving the front outer shoulders through minimising steering input with 4ws.
Front wheel camber is intimately linked to rear steering angle, all 4 wheels fight adverse centrifugal / centripetal forces, hence the strategy that RS developed, which seems sound to me. What would you have done ? Do you do much track driving ? Have you driven a mk4 RS ?
Edited by user 10 July 2019 22:17:20(UTC)  | Reason: Not specified
Offline MrRS
#42 Posted : 11 July 2019 14:39:29(UTC)
MrRS
I find it strange that just 1 deg of extra negative camber on the front negates all the supposed advantages of 4WS such as better turn in and corner stability, but there we go.
I drove a 280 Cup when the Mk4 first appeared as a demo.
#43 Posted : 11 July 2019 16:43:16(UTC)
Not strange at all, very rational. You don't need stability at that skill level ; doubling the front neg to 2 deg gives you significantly more entry and apex speed at an irrelevant cost to braking distance in this context. More than one way to skin a cat in the non binary world of suspension kinematic set ups. They wanted to promote weight loss which also maximises lateral grip. Pretty basic stuff actually.
Edited by user 11 July 2019 18:15:39(UTC)  | Reason: Not specified
#44 Posted : 11 July 2019 16:46:46(UTC)
Don’t feed the troll.
7 years away, then comes back just to berate the 280 / 300 /R.
My bet is they’ve probably had an alternative username in that time.
#45 Posted : 12 July 2019 08:38:31(UTC)
its 'mr vix" same rubbish, different username, sad but true.
#46 Posted : 12 July 2019 08:42:19(UTC)
I think its more likely to be 172RS
#47 Posted : 12 July 2019 10:51:27(UTC)
must be sad and lonely to join a forum just to troll, but hey ho, whatever floats their boats.
some of the top Porche have 4 wheel steer I believe, so it should be fine on a Renault, mixed reports, but not everyone is going to like it, and I'm inclined to go with the Renault sport engineers that it must add to the drive or it wouldn't be fitted, the R is a whole different car, made for different driving experience.
#48 Posted : 12 July 2019 15:42:17(UTC)
Quite. Along with a few other user names
2 Pages<12
