Offline RS13EDC
#1 Posted : 25 August 2019 15:01:53(UTC)
RS13EDC
Need some help on a clio RS200 edc gearbox, it’s very strange and I’ve had no help whatsoever from Renault or other car specialists.. On a hot day, the car flags up ‘check auto gearbox’, and the car is skipping gears 2, 4, 6 and reverse.. when plugged in to a OBD it’s saying clutch motor number 2.. so change that motor number 2 and still nothing.. can anyone make any suggestions! I’m being told to just get the whole gearbox changed which is gonna cost thousands or go flog the car somewhere far from home where I get no comeback, which isn’t the best advice!
Offline andy
#2 Posted : 25 August 2019 16:12:42(UTC)
andy
Check for leak between the gearbox and engine.
Input shaft seal/seals can leak onto clutches and cause this .
#3 Posted : 25 August 2019 17:49:11(UTC)
Under what driving conditions does the warning appear?
Driving in slow heavy traffic for extended periods can cause the clutches to over heat and bring up a warning and can be exaggerated in hot weather.
On Scenic 2 & 3 it used to say Gearbox over heating, but later vehicles it just brings up a generic warning message.
Also have to ask, has the vehicle been mapped or modified in any way.
Offline RS13EDC
#4 Posted : 25 August 2019 22:05:08(UTC)
RS13EDC
Thanks for both replies, there is a small leak on the bottom of the gearbox. And the car is standard, apart from modified catback. The warning message comes up, when the weather is hot, you can turn the car off and back on and it will pop back up within minutes. It’s very frustrating :( doesn’t do it in really cold weather..
