Offline LewRS
#1 Posted : 23 September 2019 23:04:19(UTC)
LewRS
25mm spacers front and back or a set of wider wheels? I know this has been discussed and looked through old discussions on wheel spacers, but nothing really informative.
Not going to put money into an RS body kit so want to give the car a wider stance, but not at the cost of safety or handling.
Views welcome and appreciated.
Thanks,
Offline karlos0891
#2 Posted : 28 September 2019 19:11:55(UTC)
karlos0891
so long as you don't go cheap spacers also make sure they are hubcentric. and go to stud and nut configuration then they will be safe. both will put more stress on wheel bearings but not a massive amount
Offline LewRS
#3 Posted : 29 September 2019 21:29:22(UTC)
LewRS
Absolutely. Will be going with Eibach or H&R only. Decided to go with them following additional consultation with my mechanic.
Thanks for the reply!
