Offline Dmrs280
#1 Posted : 04 February 2020 13:19:11(UTC)
Dmrs280
Anyone experiencing oil and coolant usage on the mk4 rs? Mines burning got as much interest in oil that the Americans are threatening war against it. Several trips to the dealer are showing no fault found apparently 🙄
Offline exiger35
#2 Posted : 05 February 2020 05:04:07(UTC)
exiger35
Need more info, how much oil you see consumed? and in how many miles, like every 1000?
Offline Dmrs280
#3 Posted : 05 February 2020 09:46:19(UTC)
Dmrs280
Mine has used 0.75L in 168 miles
#4 Posted : 05 February 2020 18:11:56(UTC)
3400mls....not a drop!
did have an oil/filter change at about 1500mls
Offline exiger35
#5 Posted : 06 February 2020 04:41:38(UTC)
exiger35
That doesn't seem normal! Most modern engines will burn some oil. 1 quart in 1500 miles is considered ok.
How many miles on your car? did you change the oil weight from the usual ?
#6 Posted : 06 February 2020 15:28:57(UTC)
No oil top up needed in its first 4000 miles. And that includes 2 track days.
I needed to top up the coolant once and added about 200ml but that's expected from new.
#7 Posted : 06 February 2020 19:39:38(UTC)
3000 miles- no oil or coolant used.
Offline Dmrs280
#8 Posted : 07 February 2020 16:49:18(UTC)
Dmrs280
13k miles. Genuine oil used (to top up with) genuine dealer serviced.
Offline exiger35
#9 Posted : 09 February 2020 06:13:44(UTC)
exiger35
You might need to take a deeper look, any blue smoke from the exhaust? Is there any misfiring or rough idle?
Have a look at the spark plugs too.
Offline ray ban
#10 Posted : 09 February 2020 16:56:13(UTC)
ray ban
Elf Evolution RN-Tech Sport 0w40?
Anybody used the Mobil 0w40 Fully Synthetic?
Offline Dmrs280
#11 Posted : 09 February 2020 21:37:03(UTC)
Dmrs280
No rough running, no smoke to report. Dealer has looked and said they can’t find a fault. But also have damaged my car in the process. Renault customer services have no interest in the whole situation. The whole things a joke to be honest.
#12 Posted : 10 February 2020 08:43:00(UTC)
Sorry to hear that. What have they done?
Offline ray ban
#13 Posted : 10 February 2020 19:58:44(UTC)
ray ban
Is it an early 280?
Did have an issue with the Oil Pump & should of had a letter for recall!
Renault Customer ServicesAngry Angry
Got a rattle behind info system.
Been 3 garages, everyone...... NOT INTERESTED.
Basically because I did not buy it from them, shocking
Been going on since December this.
Give up now.
So after 5 RS Clios, 4 RS Meganes...think, that's that!
Shame, decent car.
#14 Posted : 10 February 2020 20:21:49(UTC)
Is it an early 280?
Give up now.
Shame, decent car.
such a shame...
mine was the other way had an absolute terrible buying experience and RRG just dont know how to or just dont care about putting it right or should i say trying to right the wrong and like you could well be my last (it will be my last from RRG as they WILL NEVER GET MY MONEY AGAIN)
the original posters oil consumption is so high i am surprised its not blue smoking!!!
its a di engine so the valves will be well choked up with oil consumption like that Shocked
Offline Dmrs280
#15 Posted : 11 February 2020 06:10:55(UTC)
Dmrs280
It appears that the boot has been painted, it’s very rough and has lost its gloss finish. And my paint depth gauge will read all over the car except the boot 🤔
It had the recall in December. I too am surprised it’s not smoking
Offline exiger35
#16 Posted : 11 February 2020 07:37:15(UTC)
exiger35
If there is a problem with the valve solenoid, car should perform poorly and there should be a check engine light.
So they scratched the boot? Angry Maybe calying and polishing can smooth things out.
Offline Rusbe
#17 Posted : 11 February 2020 20:07:42(UTC)
Rusbe
Not normal consumption i think.
Mine, from April 2018 with 24689Km, has never had oil consumption and I'm going for the second oil change. I have gone through the OTS of the oil pressure solenoid valve. I had a reprogramming of injection control unit due to an error of "engine breakage risk" in 2018 with 6000km.
I use recommended oil (Elf 0W40) and check the oil every 15-30 days depending if i have time but no more than one month to check. I do about 1000km a month but I do some road sections in sports drive when i have time (2 times a month, a little sport driving).
BR.
Offline Dmrs280
#18 Posted : 16 February 2020 05:52:41(UTC)
Dmrs280
Been in contact with Renault customer service, who sent me to a body shop. £2104 to put right along with the scratches in the bonnet that have also appeared when they had it 😭
Offline Dmrs280
#19 Posted : 16 February 2020 05:53:25(UTC)
Dmrs280
So hopefully they’ll go ahead with the goodwill gesture
Offline exiger35
#20 Posted : 17 February 2020 04:52:20(UTC)
exiger35
Good to hear. What color? Also any updates on the oil issue?
Oil usage... (Mégane)
by S10 08/09/2008 15:39:23(UTC)
