Offline Jock
#1 Posted : 17 January 2010 17:33:32(UTC)
Jock
Can anyone point me in the direction of where to get the tool that screws the piston in the rear brake caliper.
I know all you have to do is push and twist on it, but i just want the proper tool so i don't damage all the paint!
Regards Stephen!
#2 Posted : 17 January 2010 17:53:08(UTC)
http://www.lasertools.co.uk/tools.aspx?cat=518
http://www.halfords.com/webapp/wcs/stores/servlet/SearchCmd?catalogId=10151&storeId=10001&categoryId=165469&langId=-1&action=listrefine&constraints=teq%7C%7CType%7C%7CBraking+%26+suspension+tools%7C%7Csor%7C%7CPrice%7C%7C1%7C%7Cpag%7C%7C2
or you can use a pair of long nose pliers that you push in to the slot on the caliper piston and apply pressure whislt turning
and they will wind back - if your concerned over the paint use a large towel or rag to protect the caliper
Offline Jock
#3 Posted : 17 January 2010 18:02:16(UTC)
Jock
YOU ARE THE MAN!!!!
Thanks Si!Approve
"or you can use a pair of long nose pliers that you push in to the slot on the caliper piston and apply pressure whislt turning
and they will wind back - if your concerned over the paint use a large towel or rag to protect the caliper"
Si you wouldn't believe how heavy handed i am!Blush
Thanks again buddy.Wink
Edited by user 17 January 2010 18:04:51(UTC)  | Reason: Not specified
Offline Pliteruning
#4 Posted : 15 April 2019 10:12:44(UTC)
Pliteruning
For similar questions, I usually refer to expert articles. Even for example, when I needed a hybrid table for sanding a tree and I was not experienced, I found a good resource - https://thecozyholic.com/best-hybrid-table-saw and there were about 10 models with different descriptions and expert opinions. This helped me to choose my model that suits my requirements. I'm sure you can also find tips on any tools that interest you.
Brake Piston Rewind Tool (Front) (Mégane)
by CurtBurr 26/03/2018 19:29:26(UTC)
Apologises for calling Mr Vix a tool and implying he is old. (General Chat)
by g7egt 10/01/2015 21:54:20(UTC)
Missing tool kit (Wanted)
by MattB 13/03/2012 23:06:07(UTC)
197 Clutch change - special tools required? (Clio)
by FlashBastd 15/09/2010 17:26:56(UTC)
Bike Spoke Tool (General Chat)
by TwingoGeekeo 04/08/2010 12:52:04(UTC)
Gem of a wheel cleaning tool!! (General Chat)
by Phil 172 24/05/2009 19:44:25(UTC)
fault reader/clip tool (Clio)
by kevo66 10/03/2009 13:32:21(UTC)
wheel cleaning tool (General Chat)
by Simonre7 28/11/2008 16:49:53(UTC)
standard hu removal tool?? (Clio)
by dotty197 21/08/2008 21:27:26(UTC)
New cleaning tool (Clio)
by Power Ranger 01/04/2008 14:31:20(UTC)
