Offline orbitalwalsh
#1 Posted : 16 May 2013 10:26:13(UTC)
orbitalwalsh
seems i have a leaky seal on the rocker cover at the back, has been for a while.
local garage being in contact said it would be a big job around 6-8 hours -£600 job to re-seat/seal as both them selves and local garage haven't performed this task on a 133.
just wondering if anyone on here or renault sport uk can give a time scale they think it would actually take or took them.
bit baffled it could take that long, understand the sealant takes time to cure etc but this is actually fitting labor...
many thanks
#2 Posted : 16 May 2013 11:26:54(UTC)
the top half of the head performs the cam carrier job as well - so the whole lot is disturbed when its re-sealed
there isnt a gasket as such just a bead of sealant as its a machined face for both parts...
thats the k4m engine which is similar to the f4r in the clio...
Edited by user 16 May 2013 11:36:19(UTC)  | Reason: info
#3 Posted : 17 May 2013 07:26:22(UTC)
orbitalwalsh
Thanks for the reply. oil's been topped up so will plod along till i can reach KTec come winter time for cam belt/ cam and piston change.
or give in the temptation of dropping a 197/200 engine in .
just gutted this will mean no track time at knockhill :(
Yet another problem,fault in either throttle potentiometer or throttle housing. (M├ęgane)
by Robbo 30/08/2018 09:54:30(UTC)
Me again with yet ANOTHER problem with my rs200 (Ownership Experience)
by wayne88 17/06/2014 11:49:02(UTC)
