#1 Posted : 24 August 2016 10:27:51(UTC)
big thank you to Adam and his team at Harrats. Car went in Friday as oil was leaking from the top of the rocker cover. Work all completed under warranty turned out to be a big job with all belts needing to be replaced.
Top service as normal and a small problem sorted quickly when I picked it up.
#2 Posted : 24 August 2016 20:01:09(UTC)
Got to say Adam is fantastic, if you're in Yorkshire or nearby Ponte is the place to go
