Offline babi13008
#1 Posted : 29 November 2018 14:49:32(UTC)
babi13008
hi, i owe megane rs 265 2014, my engine and gear mounts need to be replaced. i was looking for oem numbers but i got confused. i found too many different numbers.
can i have the right oem numbers for all gear and engine mounts? how many of these are exist?
which specific mounts are usually fail and need to be replaced?
thanks
#2 Posted : 29 November 2018 15:42:37(UTC)
Call or email Renault parts direct and they will help you out.
https://www.renaultpartsdirect.co.uk/
Edited by user 29 November 2018 15:43:13(UTC)  | Reason: Not specified
Offline Stock 265 Cup
#3 Posted : 29 November 2018 17:19:49(UTC)
Stock 265 Cup
How do you know they have failed? I own 2014 265 so would be interested to hear why they have failed.
Offline babi13008
#4 Posted : 29 November 2018 20:10:36(UTC)
babi13008
The car is shaking a bit while it’s cold. When I shift from first to second gear there is noise. I definitely sure that upper engine mount is gone also the gear mount.
If I replace 2 I consider to replace them all but before I buy I would like to know exactly how many mounts exist
#5 Posted : 30 November 2018 14:39:28(UTC)
Stock 265 Cup
How many miles has your car done? I have also noticed a knocking sound sometimes when changing from first to second and wondering what it was, been there a few months now so could be the gearbox mount I guess.
I was wanting to change the gearbox oil soon(probably over Xmas) so will get under the car, get in there have a look. You should try RSmegane.com with your question if you aren’t already on there.
