Offline alexissmq
#1 Posted : 29 March 2019 09:30:54(UTC)
alexissmq
Hello everyone!
My crank pulse sensor is dead. Max 2000RPM allowed, check engine on. P0335 fault code
My original sensor is 2-wire inductive. I ordered an 2-wire inductive sensor but the clip/coupling is too large (32mm depth). I had not find any smaller sensor..
Can i just get a cable with a small clip/coupling to fit the 32mm depth sensor? Or can i convert it to 3-wire hall-efect sensor? What can i do?
https://www.ebay.co.uk/i...cko2x&frcectupt=true - this is the product i bought
Thank you!
